Daewoo GC20SC-2 ; G6-01027
Has anyone heard of a service bulletin on this truck about the accelerator control problem? Sometimes the truck will go to idle and will not respond to the accelerator. If you reset with the key it will work again for a while; very intermit. Thanks and good luck with all those intermit problems. s.tjones at yahoo dot com
  • Posted 4 Apr 2012 21:29
  • By stephen_j
  • joined 4 Nov'11 - 34 messages
  • Indiana, United States
Good Day
Your Truck most likely has the Woodward fuel System
The ECU most likely needs a Update.
Pedal control is most likely ok so long as nobody has damaged wiring.
Have local Dealer update ECU
  • Posted 9 Apr 2012 02:26
  • By CDNTech
  • joined 31 Jan'10 - 5 messages
  • Quebec, Canada
Eric Smith
Mitsubishi Logisnext FD25T5M
Terberg YT220
Muncie, IN, United States
