Clark cps 30 travel issue
Gentlemen
Correction CPG 30
I am working on a ta 30 transaxle and i am in need of some advise.
Fault is no forward engagment. Reverse in normal.
Torque converter pressure o.k.
Fwd port pressure 246
Rev port pressure 245
Inching cable tensiton o.k.
Valves and solonoids fwd+rev are working o.k.
I removed and inspected the inching spool,looking for broken springs,sticking valves,or cracked cups and found all looks normal.
Can someone please send me a hydraulic flow diagram/schematic so i can eliminate all other possibilitys before i crack the trans and replace the clutch packs.
Thanks in advance
J
  • Posted 2 Apr 2012 03:28
  • Modified 2 Apr 2012 07:33 by poster
  • By jason_e
  • joined 2 Apr'12 - 3 messages
  • British Columbia, Canada
Luck happens when preparation meets opportunity
It sounds like a clutch pack problem.
  • Posted 3 Apr 2012 08:20
  • By rogeriwt
Did... same responce,rev o.k. and no fwd.
  • Posted 2 Apr 2012 07:31
  • By jason_e
Try swaping valves just in case. It sounds like a clutch pack issue.
  • Posted 2 Apr 2012 07:29
  • By rogeriwt
UN Forklift FBR25NQC3
Tusk 500PGH14
