crank oil seal Cat GP30
Hi, All I have been asked to replace the front crankshaft oil seal on a Cat GP30 with a 4G64 engine. Do I need any special tools or are there any pit falls I have to look out for. Any input would be gratefully appreciated.
  • Posted 23 Mar 2012 18:52
  • By nick_c
  • joined 17 Jun'11 - 116 messages
  • south glos, United Kingdom
while you have the front of the engine apart you may want to pay close attention to the timing belt and sprockets too, especially the oil pump sprocket, they have a tendency to wear out after a period of time. If the truck runs in a dirty environment that is :o)
if the belt has ANY abrasions or cracks in it, replace it. If the water pump is showing ANY signs of leaking? replace it.
oh yeah, when you put it back together and have to set the timing? MAKE SURE you time in the oil pump sprocket too, yes there is a timing mark on it as well and if it is not timed along with the rest of the engine you will get a vibration when the engine is running.
OF COURSE if your just going to pull off the pto shaft and pulleys and just pop out the seal and stick another one in there then forget all i mentioned above. I just mentioned all that since you are going to be taking it apart ;o)
ummm....oh yeah again, is this thing leaking oil out anywhere else? valve cover perhaps? if so you might want to check the pcv valve in the valve cover and make sure its free and clean. If this engine has alot of hours on it , it might just be blowby creating high crankcase pressure and replacing that seal will not help for long, it will just come out somewhere else ;o)
hope this helps somewhat ;o)
  • Posted 24 Mar 2012 23:54
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
If you replace the crank seal also replace the oil pump seal at the same time, I replace the cam seal also. They are normally hard and cracked
  • Posted 24 Mar 2012 22:18
  • By mardabas
  • joined 25 Jan'12 - 18 messages
  • Michigan, United States
front seal special tool 1068608
rear seal special tool 1068766
Does not make it science.
rear seal and give attention to the oil hole
  • Posted 24 Mar 2012 05:10
  • Modified 24 Mar 2012 05:22 by poster
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
Unicarriers FD80-2
Crown RR5225-30TT321
