SKF encoder/sensor bearings
i have got a bradshaw tow tractor T6 with Zapi AC controller, i get an encoder error every 6 to 8 months and i have to change the encoder bearing to clear the fault. i have used the same bearing on many other motors and haven't had to change them for years. Has anyone else had this problem. Could there be a controller fault etc.
  • Posted 22 Mar 2012 19:23
  • By Leon_W
  • Tyne & Wear, United Kingdom
What type of horn is fitted to your tow tractor?
BT use SKF encoder bearings on the older Reflex reach trucks & they had to fit a supressor on the horn circuit as electrical spikes could blow 1 of the motor / height counter sensor bearings.
2 pin horns the suppressor was piggy backed, later trucks used a 3 pin horn with built in supressor.
We where told if a encoder bearing was ever replaced then the horn / supressor must be replaced to & recorded on job sheet else they wouldnt warranty the part if it failed again.
  • Posted 23 Mar 2012 01:04
  • By Forkingabout
  • england, United Kingdom
Hyster
Deborah Baker Deborah Baker
Muncie, IN, United States
Crown RR5225-30TT321
Morooka MFD20
Morooka MFD20
