komatsu reach fb14rj-2 2008
intermittant trouble with reach out only, goes into very slow speed pump straining , have checked valve solenoids, swopped valve coils , removed slow down switches , reach carriage is free , ram appears ok possible sticky valve ? any one had this
  • Posted 16 Mar 2012 16:54
  • By trevb
  • joined 10 Jan'12 - 157 messages
  • avon, United Kingdom
monday is the longest day
thanks hope to swop units to another truck to prove suspect valve playing up either way sounds expensive : ( will double check serial ta
  • Posted 20 Mar 2012 08:18
  • By trevb
are you absolutly sure about this model number?
the reach truck is not a FB according to komatsu...
it is an FR and as far as the 14 part?
there is no such thing that i can find
UNLESS this is either an extremely NEW truck which i doubt as thier new truck model numbers are nowhere like this
so......
i can assume this truck is old?
or the dataplate is defaced and you are just reading it incorrectly?
please check it again....
but so i wont come across totally out of line here
in most cases i have dealt with in reach trucks
if you have issues such as this pay close attention to the wiring for the auxillary functions especially where it runs through the mast and terminates at the valve block on the carriage. and yes there is a malfunctioning valve which would explain the symptom of the hydraulic pump deadheading while in operation and the very slow movement of the pentograph cylinders. there are some check valves(some call them counterbalance valves) in the manifold block along with those solenoid valves that could be the problem too.
unfortunatly these issues are hard to diagnose most of the time and its just a process of elimination you have to go through.
  • Posted 18 Mar 2012 22:58
  • Modified 18 Mar 2012 23:05 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
yes have swopped pots still same , new type ac controller unsure of type but req laptop to enter
  • Posted 18 Mar 2012 08:10
  • By trevb
Does this use pots on the hydraulic levers or switches? If pots have you tried swapping lever pots with lift pot etc?
Also what type of controller does it use?
  • Posted 17 Mar 2012 05:09
  • Modified 17 Mar 2012 05:10 by poster
  • By elektrodrive
enquiries@elektrodrive.co.uk
Hello Trev, can you complete the model? is it an FB14RJ-2E or FB14RJ-2R.
Kind regards
marcb
  • Posted 17 Mar 2012 01:15
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Aichi SR10C1SM
Taylor TT300
USD98,500
Muncie, IN, United States
