toyota 6hbe30 no emergency reverse
no emergency reverse when button pushed all other functions ok removed and checked switch ok, tested wiring ok no opens or shorts checked pmc 7 have 22.7 volts at all times pushing emergency reverse button does not change reading
  • Posted 2 Mar 2012 08:55
  • By rick_o
  • joined 7 Nov'08 - 33 messages
roswaldheritage@hotmail.com
It is the strangest thing but the concept is if you are going through a plastic curtain and pressing the horn the truck will not reverse if the belly button is hit. Glad you got it fixed without replacing the controller.
  • Posted 10 Mar 2012 11:21
  • By rogeriwt
thank you faulty horn switch was fault as you said if follow manual leads to faulty controller, thanks again
  • Posted 10 Mar 2012 08:20
  • By rick_o
thank you will check and replace
  • Posted 2 Mar 2012 21:24
  • By rick_o
The horn button on the grab bar is faulty. It is a 4 post switch and the reverser runs to the normally closed side. Drove me nuts the first time I ran into it.
  • Posted 2 Mar 2012 10:18
  • By rogeriwt
Unicarriers FD80-2
SMV (Konecranes) 4538CCX4
Muncie, IN, United States
Unicarriers FD80-2
VETTER Forks, Inc.
Unicarriers FD80-2
VETTER Forks, Inc.
