K21L hard starting
Hey guys,
I have a customer with 3 Nissans in their fleet. MCPL02A25LV, 9P3983 is one model. These machines take several seconds to start. They are around 5000 hours each. We cleaned the oil from the vap/ Reg but no help. Plugs are original. Runs great when started. Any ideas?
  • Posted 8 Feb 2012 06:08
  • By Forkliftt
  • Louisiana, United States
Steve
steve at forkliftt dot com
Got it. Thanks.
  • Posted 11 Feb 2012 07:29
  • By Forkliftt
I would recommend nissan plugs Part #22401-FU42A they are an updated plug that has the first three threads removed as they had issues with the old plugs coming out of the head hard and taking the threads out with the plug,be VERY careful when changing plugs,do it with the engine cold and work them out easy.
I guess the threads on the old plugs get carbon build up on them and are a bear to get out of the head with out damaging the threads,especially on high hour trucks.
  • Posted 10 Feb 2012 10:14
  • By kevin_t
Thanks Radon,
Kevin has coached me on checking/ correcting the regulator pressure which I did today. The main culprit for slow starting had 4.0 psi when I tested. After removing the guard ( hard to do without the correct tool) I increased the pressure to 4.8 which helped tremendously on starting.
I still think new plugs would be a great idea given so many hours. Is there a "best" brand of plug to use?
  • Posted 10 Feb 2012 10:08
  • By Forkliftt
I'm not sure what year these trucks are but if you cannot connect laptop you can take out pressure sensor and use that port for fuel pressure, that way your sure its getting to injector body. There is a screen in the inlet side of fuel that can become plugged. I would check your plugs weak spark may cause hard starts too, amongst many other things.
  • Posted 10 Feb 2012 03:17
  • By radon
  • joined 28 Sep'11 - 62 messages
Got it! Thanks for the info you sent as well.
  • Posted 8 Feb 2012 09:44
  • By Forkliftt
top of the regulator(NIKKI) is a 17 mm hex take it out and can screw a 1/8 NPT nipple in it(dont force it in tho,just finger tight) and check the pressure,see what it does also under load(tilt bypass) should hold around 4.5 PSI
  • Posted 8 Feb 2012 09:28
  • By kevin_t
Kevin, I didn't. I have a low pressure gauge to check Impco model J's. Where would the test port be?
  • Posted 8 Feb 2012 09:25
  • By Forkliftt
Possible Vaporizor problem,did you check your fuel Pressure coming from the vaporizor,should be about 4.5 PSI.
Even if you drained the tar could be problems with it causing problems.
  • Posted 8 Feb 2012 09:01
  • By kevin_t
edition #1238 - 10 July 2025
UN Forklift FGL25T
UN Forklift FB25N1QZ1
September 23-25, 2025 - SÃO PAULO, Brazil
October 15-16, 2025 - Las Vegas, United States
November 25-26, 2025 - Singapore, Singapore
The dot-com bubble, a period of large and rapid investments in internet-based companies, peaked in 2000 and saw the Nasdaq Composite index rise by 579%. Then the bubble imploded. As the value of tech stocks plummeted, cash-strapped internet start-ups became worthless and collapsed.
