code e38 on a nissan platinum lo2
replaced vaporizer and 2 weeks later code e38 appears on dash.lpg over pressure.i found harness at the relay box near foot rail corroded,repaired wires.btw truck has approx 2600 hrs.any help
  • Posted 1 Feb 2012 11:30
  • By roc109
  • joined 2 Nov'09 - 51 messages
I would check your pressure coming out of the vaporizor,on top of it should be a 17mm hex,take this out and put a pressure gauge in and see what it is,should be 4.5 PSI ,did you replace or rebuild the regulator? Pressure might just need adjusted.
  • Posted 1 Feb 2012 21:09
  • By kevin_t
roc109,
This probably means that the LPG fuel pressure sensor haas shorted out or that an abnormal rise in the fuel pressurein the fuel pipe from the lpg vapo to to the injector continuse for any length of time. Remove the fuel pipe from the injector turn the ignition switch to on you should hear a quick hiss and it should fall away to nothing if ok.
Regards Titus
  • Posted 1 Feb 2012 19:49
  • By Titus
  • joined 6 Jul'10 - 185 messages
F. Uchiyama
Deborah Baker Deborah Baker
Crown RR5225-30TT321
Enforcer FD50T-MMA
