Diagnostic Code Help
We recently purchased a 2005 S60FT unit. Upon its arrival from the place of business we bought it from the unit would barely move. It is like you are standing on the brakes and the gas at the same time. The dealer wanted me to have the local hyster tech come and get the codes from it. He retrieved the following codes from the computer.
177-3
2000-12
524245-4
524233-4
524225-4
524269-3
522655-1
523859-3
522781-2
522810-4
2236-12
The tech said it is probably wiring shorts that is causing so many codes in the unit. I didnt ask him what they all were because i wanted to go back to the dealer i bought the unit from. They now are giving me a big run around on it.
Can anyone tell me what each of these codes are?
Thanks
Andy
  • Posted 11 Dec 2011 00:11
  • By chevelless502
  • joined 11 Dec'11 - 9 messages
  • Illinois, United States
My view is wrong impedance.
I would check the PDM.
Mostly negative lead to ground and battery.
So many errors can cause incorrect impedance.
And this is a problem in 2011.
I'm looking at the forum since 2008
I am honored that watch us well as past issues
You need something?
THX
  • Posted 8 Feb 2014 08:04
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
geroj is definatly onto something there
with all these codes dealing with voltage issues all over the place i would certainly check the battery and load test it. If bad then replace and then see how truck runs. Most of these codes will dissapear probably but with those that are persistant , try clearing them, if any return then deal with those.
if you have never been into the computer system through the dash before i would not do it without 'onhand' assistance. Even with the manual not knowing what you're doing could result in bad things happening. Even as much as i or geroj or anyone else may want to help you with this part i wouldn't recommend it without 'onhand' assistance.
Just my.02 on this...
you can do what you want though
good luck
  • Posted 8 Feb 2014 05:09
  • Modified 8 Feb 2014 05:13 by poster
You have access to the display?
5x5
  • Posted 8 Feb 2014 04:26
  • By geroj
  • Krivan, Slovakia
How can I delete the codes ?
  • Posted 8 Feb 2014 02:55
  • By tarek_b
  • joined 7 Feb'14 - 6 messages
  • annaba, Algeria
I first delete the list of errors.
Then replace the battery.
Give your mail to your profile
  • Posted 13 Dec 2011 05:44
  • By geroj
  • Krivan, Slovakia
SERIAL# F187V01869C
  • Posted 11 Dec 2011 06:01
  • By chevelless502
having a correct serial number (or at least the series) might help to be sure you get the correct information.
  • Posted 11 Dec 2011 05:07
Tusk 350CGH20
Terberg RT223
Tusk 350CGH20
Terberg RT223
