EV100
I have an old Crown. Forward and reverse contactors would come in when the pedal was pushed. No travel. Went through check list and everything pointed to EV100 card. The card I took out was IC3645EV. Went to Crown and they gave me IC3645LXCD1. Now when I connect the battery 1 contactor comes in right away and when I push the pedal nothing at all happens. Is this the right card??
Thanks For Your Help
Jan
  • Posted 17 Nov 2011 03:32
  • By jan_i
  • joined 17 Nov'11 - 4 messages
Jan
Make sure that terminal #1 wire 29 reads 4.5V when you press pedal it linearly drops to 0v
I think you messed up the wires when you wired it in.
Terminals 2,3,4 should have batt pos
5 is FW input batt pos
6 is RW input batt pos
#1 terminal starts on top from left with small connectors x, y on left, 2 large conn pcb pca on right
  • Posted 17 Nov 2011 09:38
  • By ivan_j
  • joined 16 Feb'11 - 65 messages
ivan.forklift.man@gmail.com
Did you make absolutely sure it was the card that was the problem to begin with? Did you have any codes either on dash or use a LX handset to see if any codes were stored in the card? What model and S/N of the truck? Does sound now like card is wired in wrong or something else isnt right with the installation
  • Posted 17 Nov 2011 07:47
  • By kevin_t
I think you messed up something. Looks the same card. Or card is defective.
  • Posted 17 Nov 2011 06:06
  • By ivan_j
UN Forklift FD50T-NJB3
Morooka MFD20
Kai von Berg Kai von Berg
