Capacity Rate
I need your help to identificate this machine. Its a Hyster with serial stamped in chassis number A177B22880H. equiped with 4 cyls. IZUZU diesel engine. I need to know the rated capacity load
to avoid a problem with this.
Anyone can help! Thanks in anvanced.
  • Posted 8 Oct 2011 02:30
  • By pastrana_j
  • joined 3 Aug'10 - 103 messages
  • Puebla, Mexico
The basic lift capacity is 4000 lb. at 24" LC. The net lift capacity may be different depending on how the unit is equipped - i.e. two stage mast or 3 stage mast, mast max. fork height, attachments (side shift, fork positioner, etc), amount of mast tilt (fwd/back). This info needs to be made known first before a capacity rating can be given.
  • Posted 9 Oct 2011 12:11
  • By johnr_j
"Have An Exceptional Day!"
It should be a 1987 H40XL (H2.00XL) with a Isuzu C240 (5.2L) motor, it was built in Tacoma,Washington by Star Iron & Steel Co. It weighs 7750lbs or 3515kg and has a lift capacity of 4000lbs at 24" load center.
  • Posted 9 Oct 2011 11:43
  • By roadtech
UN Forklift FBT18NQZ1
UN Forklift FBR25NQC3
Kai von Berg Kai von Berg
