CAT F30D only left drive motor works
Hi @ all Cat-Experts,
Maybe you can help me.
On a CAT CB Electric Truck F30D I have no power on the right drive motor(When you seat on truck). If you press the acc pedal full down and the bypass connector closes than both motors works normaly with full speed.
Any idea?
OK are: Fuses,All Connectors&Coils, 4 Diodes, 2 Transistors, Motor Cables, Left & Right Motors (Checked with changing cables), Steering
Thank you very much for your time!
  • Posted 4 Oct 2011 01:02
  • By koett
  • joined 16 Oct'10 - 7 messages
  • thessalia, Greece
koettdaagreek@gmail.com
koett;
With what information you have I can only take a wild guess. It would be useful information if the S/N group was known and if you have performed the on board diagnostics witb the Micro Command operating system. So you have only one of the two drive motors in normal operation. What is showing in the display? What faults if any are shown? Are power steering and lift operations normal? Depending on your answers will determine if you have open 1 TRN R or L; open motor circuit between TRN and motor; defective driver board; open plug sensor wire; open current sensor circuit; a defective #4 or #5 diode Ror L of course; defective logic card.
  • Posted 4 Oct 2011 03:48
  • By MEngr
  • Missouri, United States
Crown RD572513TT6860R
Taylor T650L
September 23-25, 2025 - SÃO PAULO, Brazil
October 15-16, 2025 - Las Vegas, United States
November 25-26, 2025 - Singapore, Singapore
Cleveland Ohio, United States
Wentzville, MO, United States
Columbia, SC, United States
The dot-com bubble, a period of large and rapid investments in internet-based companies, peaked in 2000 and saw the Nasdaq Composite index rise by 579%. Then the bubble imploded. As the value of tech stocks plummeted, cash-strapped internet start-ups became worthless and collapsed.
Laura Ness Owens Laura Ness Owens
Chief marketing officer, Bobcat Company
Chief commercial officer, Teradyne Robotics
CEO, MHEDA
President, European Rental Association (ERA)
