toyota 8HBE30 Rabbit button Problem
This rider palletjack only has rabbit funtion in one direction. Does anyone Know if this is a funtion that can be disabled and enabled threw the key pad or do I need a hanset?
[email address removed]
  • Posted 29 Sep 2011 12:09
  • By pelayos1
  • joined 20 Sep'11 - 8 messages
Thanks rogeriwt,
Are you 100% sure of this? Please let me know, All of the rider palletjacks I've seen have rabbit funtion in both dirrection.
  • Posted 2 Oct 2011 04:03
  • By pelayos1
Thanks steponmebbbboom,
Sounds like you know something about this toyota model, Can you corfirm that the rabbit funtion is only active in one dirrection. Thanks again for the info on the key.
  • Posted 2 Oct 2011 03:58
  • By pelayos1
The service parameter for Rabbit Speed cannot be adjusted for individual directions. I believe this is a normal characteristic of the machine, because travel direction is usually with forks trailing. To adjust service parameters a "service key" is required. It is a small box with a serial cable coming out of it. The Toyota part number for this service key is 00590-42683-71. Sale of the key is restricted, but if you have a friend in the business they may be able to procure the key for you. I myself cannot. Good Luck
  • Posted 30 Sep 2011 07:23
  • By steponmebbbboom
As far as I know there is no way of changing that.
  • Posted 30 Sep 2011 07:19
  • By rogeriwt
Kai von Berg Kai von Berg
