Hard Steering
Hard steering ! engine pump ok psi o.k od time just get stiff and if you use the tilt or other functions the steering loosen up.Could this be a valve problem or hose connected in the wrong place? any suggestions
  • Posted 9 Sep 2011 04:47
  • By LOGIC
  • joined 6 Dec'08 - 70 messages
check priority valve. Dismantle it an clean it inside. Check tensioner spring of the valve if is broken.
  • Posted 9 May 2013 09:28
  • By StillCAT
  • joined 9 Apr'13 - 18 messages
  • Bucharest, Romania
Esie Cortez Esie Cortez
