Komatsu M/N FG15-14 clutch replace
Info. in changing clutch on a FG15-14 Komatsu, it has the Toyota 4P engine & is a 1985 truck
Thanks
  • Posted 13 Aug 2011 05:51
  • Modified 13 Aug 2011 07:56 by poster
  • By joe_a
  • joined 16 Apr'09 - 4 messages
Thanks again Marc. Maybe someday I can return the favor.
Joe A. (liftruckman)
  • Posted 14 Aug 2011 22:28
  • By joe_a
Hello Joe, as far as I know there's enough space to remove the complete clutch group without putting pressure on the clutch fingers (for a diesel engine it's another matter), just make sure that the clutch release bearing has moved completly to the end.(transmission side)
Kind regards
Marc
  • Posted 14 Aug 2011 20:30
  • By marc_b
  • joined 1 Jul'05 - 345 messages
  • ANTWERP, Belgium
Thanks Marc., thats good news. Anything special I should know on removing or sliding back the main shaft. Do you compress the fingers on pressure plate, thd. size of the bolts used to collapse it or do you nuts between fingers & cover plate, etc..
Thanks, liftruckman
  • Posted 14 Aug 2011 00:03
  • By joe_a
hello Joe,
It can be done without removing the motor, just remove the cover from the transmission house. it takes about 45 minutes to remove and install a new one.
Good luck
Marc
  • Posted 13 Aug 2011 15:44
  • By marc_b
  • ANTWERP, Belgium
Thanks for the reply. I was hoping it could be done by slinding the main shaft back as it has the Toyota 4P engine.
  • Posted 13 Aug 2011 07:52
  • By joe_a
Old School Guy
Not quite sure what you're asking but you support the trans and bell housing, remove motor, install new clutch, put motor back in, for a clutch job.
  • Posted 13 Aug 2011 06:41
SMV (Konecranes) SL37-1200A
Unicarriers FD80-2
