Toyota 7BPU15 Serial# 80341 Code 32
Hey Guys,
This lift will not travel and will only steer to the right. Have checked multiple wires and have not located a break yet. Please help with code and any other suggestions for repair. Thanks. E-mail is in my profile.
  • Posted 12 Aug 2011 04:22
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
Work Hard and Fish Long
Glad that fixed it.
  • Posted 9 Sep 2011 07:44
  • By rogeriwt
Just to give an update on this machine, the Power Head Card was bad. Had it rebuilt and everything is working fine. Thanks for the help.
  • Posted 9 Sep 2011 00:05
  • By garland_m
no problem Garland. They can be such a pain, hopefully that cures it.
  • Posted 19 Aug 2011 10:08
  • By rogeriwt
Roger,
Thanks for the help, we took the main control card and installed in a known good running machine and had no problems. We think the power head card is bad so we sent it to Flight Systems to have them check and possible repair. Thanks for the help.
  • Posted 18 Aug 2011 23:14
  • By garland_m
I believe that the main card sends the signal to power head card and the power head card supplies the current to the motor. I usually use the laptop to diagnose, I think that you are looking for current flow. The other way is to put in a known good part and see if it works.
  • Posted 18 Aug 2011 11:59
  • By rogeriwt
Hey Roger,
We swapped with same unit and the card, motor and gear box check good. We found another card, steer power head card. How does this affect the main steer card and how would you troubleshoot. Thanks for the help.
  • Posted 16 Aug 2011 01:34
  • By garland_m
I ran into this once and it ended up being a STM card. They are known for going.
  • Posted 12 Aug 2011 06:48
  • By rogeriwt
