hello,
I'm looking for codes to calibrate the gearbox, is it possible to calibrate their own?,
thanks you in advance for your reply
Hi edward, usually calibration process takes around 15-20 minutes
Ian, how long should the calibration take (using the apc200)? not the labor to get to the apc200, just the waiting.
serial number is 331052429 year 2008, thank you very much.
Best Regards, Alan
Hi, do you have the serial number of the machine? depending on the age of the machine, to calibrate the transmission you do it either via the APC 200 itself or through the drivers screen. if you can give me the T number i will be able to give you the procedure to calibrate the transmission. BR Ian
