Toyota 7fbeu15 48 volt ac
forks raised will not lower, cracked emergency screw on valve forks now lowered , what could be the problem. solenoid at the bottom of the control valve, what should be the voltage at connector plug. thanks
  • Posted 7 Jul 2011 11:32
  • By towmotor
  • joined 19 Feb'07 - 360 messages
HI mate
The error as stated above seems to be related to your valve coil. Unfortunately I cannot seem to find this info on the manual that I have, after error 62 it jumps to 66. I cannot remember where I had got this info from originally.
Regards
  • Posted 14 Jun 2012 02:19
  • By elektrodrive
enquiries@elektrodrive.co.uk
Dear sir,
I have also a problem with my truck. The fork can not lower and display error code 64-1.
Can you help me with drawing or service manual for troubleshooting.
Contact with me via email: trung_klc@machinery dot com dot vn
Thanks & Regards
  • Posted 14 Jun 2012 00:04
  • Modified 14 Jun 2012 00:08 by poster
  • By David_nguyen
  • joined 14 Feb'11 - 91 messages
  • Binh Duong, Viet Nam
Hi Mate
64.1 = lift solenoid open.
It says if the voltage at the lift solenoid valve is above 5v then you have a faulty solenoid valve.
Check the resistance to the solenoid valve for the lift and compare it to the working solenoid valves. If the voltage is below 5v after key is switched on.
  • Posted 9 Jul 2011 05:07
  • By elektrodrive
HI ELEKTRODRIVE. I ONLY SEE MICRO SWITCHES ON TOP OF CONTROL VALVE. TILT AND SIDESHIFT OK DASH DISPLAY, SPANNER, WRENCH ALSO 64.1. THANKS 11OOOHRS ON TRUCK
  • Posted 8 Jul 2011 10:11
  • By towmotor
Hi Mate
Is it throwing up any error codes? Can you hear the motor pulsing or trying to pulse even though it does not lower?
Does the other attachments tilt for example tilt up and down? If so try swapping the pot levers around and see if that makes any difference?
  • Posted 8 Jul 2011 03:42
  • By elektrodrive
Terberg YT223
TCM FD115-3
