CAT GC25K AT82D - Brakes
Installed new shoe and wheel cyl on unit. When installing drum, it crowds or is rubbing on the backing plate and shoes. to the point were it locks up. Any ideas thx in advance
  • Posted 7 May 2011 06:34
  • By Prentice
I am not sure how the axle is secured on this truck, but i have had problems with some Cat machines where the axle wears in the holder but the back plate is bolted to the axle holder. This leaves the drum not lining up with the backplate and shoes. check that there is no movement up and down in the axle relative to the backplate.
  • Posted 8 May 2011 02:15
  • By AndyPandy
looks like the drum has been rubbing on the backing plate for some time. We have checked and double checked part #'s and compared old and new shoes. It seems like the axle is pushed back for some reason????? A head scratcher.
  • Posted 8 May 2011 01:49
  • By Prentice
Did you get the right shoe on the right side,i believe the shoes are diffrent for the left and right if they are mixed up it might be the problem?
  • Posted 7 May 2011 22:32
  • By kevin_t
Hawker Powersource, Inc.
Toyota 8FG25
TCM FD115-3
