Mitsubishi FG15N EF34L
Starting problem when cold.
have problem to start when cold, it dont get gas.
can start it on spray and after there is no problem, have cleaned the micser and carburator.
any that have a sugestion
  • Posted 4 May 2011 15:54
  • By bjarte
  • joined 24 Sep'09 - 63 messages
  • 5911 Alversund, Norway
post at 2talservice dot no
There is no code in dash have check the relais all ok.
If you just get it to start it will work for some days.
There is never problem when hot.
Wondering if it is signal from temp or the halve on carborator
  • Posted 4 May 2011 21:33
  • By bjarte
no codes?
checked the relays?
  • Posted 4 May 2011 20:24
