Hyster J 1.60 xmt
Best of all, I have a problem with a hyster 1.60 xmt
e160a01665u with serial number, put the PCB
new traction now in the display code
error 11, which means the code 11 error?
Thank you very much.
  • Posted 30 Mar 2011 06:57
  • By fernando_r
  • joined 5 Mar'10 - 33 messages
  • Spain
Dear, Fernando
Contact by E -Mail
Thanks
Robin
  • Posted 30 Mar 2011 08:56
  • By robin_l
  • joined 31 Oct'10 - 27 messages
  • netherlands, Netherlands
-11
The START switch is closed when the key
switch is closed and voltage is applied to the
control card
Indication of Fault
Forward or Reverse contactor will not close.
Possible Cause
START switch needs adjustment or is damaged.
Input voltage must be less than 60% of battery voltage
when the key switch is closed. Replace or adjust the
START switch.
Short-circuit between battery positive and TB2 in
START switch circuit.
Disconnect the wire from TB2. Check for a
short-circuit between the end of the wire and the
battery positive. Resistance must be greater than 4.7
K ohms.
Control card malfunction.
Disconnect the wire from TB3 and measure the
voltage from TB3 to battery negative. If the voltage is
not zero, replace the control card
  • Posted 30 Mar 2011 08:32
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
SMV (Konecranes) 33-1200C
Nagano NUL120-6
VETTER Forks, Inc.
Nagano NUL120-6
