TCM FD70
Hi,
Can anyone tell me the best way to do a ring gear on a TCM FD70
is it to take engine out, take engine and trans out or take the trans out separately, plus any hints.
Thanks
  • Posted 18 Mar 2011 08:08
  • By peter_d
  • joined 4 Jun'09 - 50 messages
  • manchester, United Kingdom
Thanks for the info mrfixit I have not seen the truck yet we have been asked for quote to do the job, does the engine and trans have lifting points, do you use a block and tackle to support the engine from the overhead guard or use a jack/wood from underneath.
  • Posted 20 Mar 2011 20:38
  • By peter_d
How about not taking anything out except the ring gear? Remove the seat, radiator, exhaust pipe, air filter hose, and fan. Remove hoses to the pump. If the pump is behind the motor, I guess you have to take it off. Remove the bell housing, motor mount, and torque convertor bolts. Leave everything on the motor, just support the motor and trans. as needed. Pull motor back, hopefully 6", but 4" can work. Reach in there and take the flywheel off. Try to be done in time to knock off for lunch early :-)
  • Posted 18 Mar 2011 09:44
  • Modified 18 Mar 2011 10:49 by poster
