Boucing carriage
This is a bad flow valve I think...or what else could be the problem of the bouncing?
  • Posted 12 Mar 2011 02:22
  • By fredz0003
  • joined 25 Feb'11 - 69 messages
Raymond Action
(Raymond/r35-c35tt) as for the serial number is 05953. It bounces when lifting up and down, when I let go the control handle it bounces just a little. It does have a bleeder but already did that. I noticed on other truck same model it doesn't bonce when you release the lift **** instead it stop at once. and it bounce with or without a load.
  • Posted 12 Mar 2011 03:43
  • By fredz0003
Raymond Action
A little more information may help us give you a far better guess as to what you are asking.
model? serial? make?
when does it bounce? driving empty and not touching the controls? while lifting? when you stop lifting? loaded or unloaded? in reverse? only when changing directions?
how high does it bounce? does it have a bleeder on the lift cylinder? does it have fingertip controllers or levers and linkage to the control valve. does it have a hydraulic accumulator?
  • Posted 12 Mar 2011 02:51
  • Modified 12 Mar 2011 08:17 by poster
Taylor X550M
JLG G12-55A
Kai von Berg Kai von Berg
Taylor X550M
JLG G12-55A
