Can someone help me I.D. this Forker
I can not find any ID tag on this fork, I bought it from a bankruptcy auction and no one knew anything about it. It is a Yale, 6cyl. chrysler flat head, 230 CI. about mid 60's (my guess) Hi/Lo range 2 speed (1forward/ 1 reverse) 15" tires in front. Where should the id plate be located? is the clutch a standard physical clutch or hydraulic? lifting capacity???
  • Posted 23 Feb 2011 07:01
  • By awert
  • joined 23 Feb'11 - 2 messages
  • Minnesota, United States
Thank you very much for your information, much appreciated, very helpful.
  • Posted 14 Feb 2013 10:18
  • By Tracky
  • joined 9 Feb'13 - 2 messages
  • Queensland, Australia
Get back on track!
In assuming your truck is a manual transmission model- yes, the trans & diff are a common resevior. Drain the water from the 2 drain plugs you saw, remove the level plug in the front of the diff & fill through the fill port in the trans. Use multi- viscosity gear oil 90-120. Should take 8 pints according to the manual.
  • Posted 11 Feb 2013 23:36
  • By bbforks
I've got a G51P Yale forklift and I've been trying to get it working. The gearbox was full of water and I'm trying to locate some information about the oil type it takes in the transmission and diff. It appears that it's all one oil, is that correct?.. and the only level bung I can find is at the front of the diff. and the only filler I can find is on top of the gearbox/diff in front of the selector. I'm just confirming if this is the only level bung and filler for both the transmission and diff as there is 2 separate drain bungs underneath. I would greatly appreciate your information and advice on this matter.
  • Posted 9 Feb 2013 13:23
  • By Tracky
Get back on track!
I was a Yale dealer road tech in 1979. A customer of mine has one of those in great condition. Let's me PM it once a year.
  • Posted 23 Feb 2011 12:31
here is a pic, add your own http and remove the spaces around the dots:
ny. forktechs. com/Img0979. JPG
Mrfixit just about wins the "dang you old and still remember things" category...
  • Posted 23 Feb 2011 12:18
  • Modified 23 Feb 2011 12:20 by poster
G51P had the Chrysler flat head
  • Posted 23 Feb 2011 12:06
  • Modified 23 Feb 2011 12:08 by poster
not a G83P as it had the OHV Chrysler H225 slant 6.
  • Posted 23 Feb 2011 11:04
  • By johnr_j
I'm sure it is a Chrysler 6L..... tires are pneumatic, I will look for some ID. I just never knew WHERE to start looking...you think it may be G83?.....run's great but i would like to get a manual, probably off ebay.
  • Posted 23 Feb 2011 10:15
  • By awert
1. Look on the frame member on the front cowl between the mast and chassis for a truck serial number stamped in the frame. If the unit has been repaint several times you'll need to to some paint scrapping..
2. Are you sure the engine is a Chrysler flat head - seems to me in the 60's Yale used Continental Flat heads 4 (F163) & 6 (F227)cylinder & in the late 60's or real early 70's went to the Chrysler slant 6, H225 OHV engine in their G83C & G83P series.
3. Are the tires press on solid or pneumatic (truck tire style) shaped. The complete tire size should be on the sidewall of the tire
4. Back them the nameplates were aluminum plates pop riveted on the dash or seat deck or in the operator foot area on a vertical member - look for 4 holes that form a rectangle in this area. If you find them & no plate - it's missing. You'll need to find the s/n.
Hope this helps - being that old, parts will be hard to find anywhere.
  • Posted 23 Feb 2011 09:45
  • By johnr_j
can you post a picture some where, or send it to me and I will post it?
  • Posted 23 Feb 2011 08:37
Deborah Baker Deborah Baker
Muncie, IN, United States
