Wheels falling off
My users would occasionally experience one of their rear wheels falling off. Not always the case of loose wheel nuts but damaged bearings.
Anyone experience the same? I don't really know the cause(s).
Our initial response would be it was due to users abusing the forklift by driving over kerbs or bumps. But I somehow feel it may not always be the case.
Anyone with advise or experiences to share?
  • Posted 2 Aug 2006 17:32
  • By chewingyu
  • joined 28 Oct'05 - 73 messages
  • Singapore, Singapore
too much grease? never heard that one
  • Posted 26 Apr 2008 09:57
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Hyster trucks have a little lip on the rear axle that if you don't get it over it well chew the bearings and axle up.
  • Posted 25 Apr 2008 22:50
  • By David
  • joined 25 Apr'08 - 2 messages
  • Indiana, United States
hi guys
the steer axle set up in this truck is too light for 3 ton useage. hyster advise more frequent inspection required. but they say that on most of there common failures
regards
kevin
  • Posted 22 Aug 2006 03:47
  • By kevin_k
I tend to see more bearing failures on cushion tire trucks.
The 'suspension' provided by the pnuematic tires saves the bearings from much of the shock-loading.
There are many installation problems that can cause premature bearing failure;
too loose
too tight
spindle damage
not enough grease
too much grease
wrong grease
etc...
I believe in installing the bearings a little on the tight side. My logic being that the wheels never do more than about 20-30 rpm, so heat is not much of a factor, and it will help prevent brinelling by distributing the load around the entire race.
I have better luck with moly-h lube as opposed to ep2.
When you examine the failed bearings, what do you see? Is the grease burnt? (ie. stinky) Race failure or roller?
  • Posted 4 Aug 2006 01:33
  • By mike_n
  • Alberta, Canada
Muncie, IN, United States
SMV (Konecranes) 16-1200B
UN Forklift FB25N1LZ1
