TRANSMISSION FAULT
HAS ANYONE HAD A PROBLEM WITH THE DRIVE ON A DAEWOO D30S-3. ON SELECTING DRIVE THE TRANSMISSION TAKES AWHILE TO TAKE OFF. I HAVE CHECKED PRESSURES AND CHANGED OIL/FILTERS, IT JUST SEEMS AS IF YOU ARE RIDING A CLUTCH ON A CAR, ANY HELP APPRECIATED.
  • Posted 28 Jul 2006 02:54
  • By simon_a
  • joined 28 Jul'06 - 17 messages
  • south yorkshire, United Kingdom
WE CAN ALL GET THROUGH THIS TOGETHER
Check the small filter inside the cushioning valve,if its slow changing directions this could also be the problem.Take it out and blow it out,or use a paper clip to remove any obstructions.
  • Posted 10 Oct 2007 06:07
  • By alan_m
  • joined 20 Apr'07 - 72 messages
  • United Kingdom
It sounds like the "cushioning" valve is stinking or slow to react or there is excessive clearance in the clutch packs due to wear.
  • Posted 18 Aug 2006 11:56
  • By charlie_j
  • joined 5 Nov'04 - 46 messages
also check ur inching adjustments if thats outta wack itll seem like its losing power slow to engage and no power/slips uphill
  • Posted 18 Aug 2006 10:09
  • By justinm
It seems some of your Transmission discs and mating disc (plates)have overheated and non-functional. Need to open the automatic transmission and replace. Please also check the solenoid which operates the gears forward and reverse that also could be a problem.
1st solenoid and then go to the discs and mating plates
  • Posted 17 Aug 2006 18:45
  • By ajdxb
  • joined 6 Jun'06 - 7 messages
  • United Arab Emirates, United Arab Emirates
Esie Cortez Esie Cortez
Oxford Ct, United States
UN Forklift FBRS15KQZ2
TCM FD80Z7
TCM FD80Z7 1990
