Toyota 7FDU60 13Z pump timing
Anyone know how to set injector pump timing on a 13Z diesel and what tools I need to buy.
Thanks in advance
Willis
  • Posted 14 Oct 2010 05:50
  • By Willis
  • joined 14 Oct'10 - 9 messages
I don't suppose you have any of the information as per normal, I bit off more than I can chew and have a lift to go back together with a new pump with no marks and a 13z that needs it to run.
  • Posted 24 Dec 2024 00:46
  • By Eamonn_Young
  • joined 24 Dec'24 - 4 messages
Eamonn Younh
Did get the advice you needed, if so can you pass it along to me.
I have the same issue with a 15Z engine. I mark the tooth before
Removing the pump. Had pump rebuilt, had etched a mark on the gear
And housing, when I got pump back, I marked the tooth again with
white paint put it in, and now it won't start.
  • Posted 1 Nov 2019 01:27
  • By John_Rogers
  • joined 26 Oct'19 - 5 messages
John Rogers
GOOD MORNING
i have a 13z that the pump that was sent by the customer is not in time and i have to retime it and install it could you give me some advice on the proper way to do this thank you
  • Posted 19 Apr 2018 22:38
  • By bobby_l
  • joined 16 Jul'17 - 3 messages
good morning i to am having timing problems with a 13z any help would be greatly appreciated cant get non of the parks to line up to put the pump in and time it thank you
  • Posted 16 Jul 2017 23:25
  • By bobby_l
BOBBY LOYA
I also need pump timing in for for 13Z Toyota engine
  • Posted 16 Jul 2016 03:36
  • By rob808
  • joined 16 Jul'16 - 2 messages
  • Hawaii, United States
Do you have any info on how to time a 13 z toyota engine injection pump
  • Posted 25 Sep 2014 10:30
  • By jay_f
  • joined 25 Sep'14 - 3 messages
yep
Thank you very much for your advice. Worked perfect.
  • Posted 16 Oct 2010 02:10
  • By Willis
you've got one **** of a mess on your hands. check your e
  • Posted 15 Oct 2010 12:18
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
The lift showed up in pieces. I am now putting it back together.
  • Posted 14 Oct 2010 10:29
  • Modified 16 Oct 2010 02:11 by poster
  • By Willis
your email. did you already pull this pump without marking it? if so you have your hands full at this point.
  • Posted 14 Oct 2010 08:42
  • By toyzilla
Spencer/Sheldon/Sioux Rapids, IA, United States
Toyota 8FD45
SMV (Konecranes) 16-1200C
December 03, 2025 - New Delhi, India
