trans
have a trans that makes a loud noise/also slips took it apart clutchpak looks good /pressure test was not done took over for another tech. All brgs will be replaced/seals including pinion.The trans fluid was slightly off color but no burnt smell??
  • Posted 22 Jun 2006 09:16
  • By jerry_o
  • joined 18 Jan'06 - 14 messages
Jerry,
You have to take the pressures before you take a trans apart. It tells the entire story espically if you are having a slipping issue.
Pump, Converter, forward and reverse pressures can show you were to look for internal leaks that you otherwise would never know about or know to look for during your tear down.
You may get lucky and by replacing all of the sealing rings on the clutch drums and pump that you had replaced the one that may have been leaking internally and causing your slip.
But had you taken the pressures you would have known if you had a pump problem, or a clutch drum problem or possibly a controll valve problem.
I am sure that the "off color" fluid would have eventually gotten burnt had you not taken the unit out of service.
Good Luck, we have all been guilty of short cuts at one time or the other, but I have learned the hard way too.
Typically Nissan single speed transmissions are pretty bullet proof and not a real mystery. My guess is that you will find a sealing ring, port obstruction, or week control valve or that the inching circuit is not adjusted correctly, based on clutches and drums looking good.
  • Posted 7 Sep 2006 23:15
  • By scott_f
  • joined 13 Oct'05 - 4 messages
  • Wisconsin, United States
Crown WP302020
Toyota 02-8FD25
Esie Cortez Esie Cortez
Crown WP302020
Toyota 02-8FD25
Libiao Robotics
