I am restoring a STILL R70 forklift (1988). It has serious electric problems both the control circuit boards are suspect. Does anyone have the details on the boards?
Please help me out.
Thanks
Jerry
Showing items 1 - 20 of 36 results.
i have the same problem with a diesel truck
https://hellodear.in
https://teatv.ltd/get-apk/
I have the same issue with our truck. Could you send me the wiring diagram as well. That would really help me out!
Hi boys ,r70-25 mercedes engine , drive pcb nobody has news?
contact i will pay
myamev8 at hotmail. com (no spaces)
Beautiful day!
I would like to ask big help!
I took it as myself one 1990 es Still R70-30T trolley. How that mistake of his is not going unfortunately neither ahead back. I would like to ask a drawing from him, if solvable. Dared unfortunately do not find nowhere.
I would be very grateful if you would be able to send it!
Ahead thank you very much!
With respect Csaba
[email address removed]
Hi Manuel. Did you find electric schematic for power board I have similar problem. On electric drive motor exiter is always under power and draw more than 20amps power from battery. Nothing change when I remove key.
Hi Jerry,
Helo,
I have a STILL R70, from 1988, with VW diesel.
I need the wiring diagrams, if any body can help.
The same problem with driving, the other things working.
Thanks in advance
Hi,
do you have Electric scheme for still R70? Pls send me.
Thank you
Jan
Hello.
We have Still R70-20 Mercedes Diesel Electric Truck 1988/9, We want to change the starter ring gear. Can anybody give us a procedure for removing the generator to get to the flywheel to replace ring gear.
Hi, i have a still R70-16 triplex with a VW engine and is powered by LPG.
The engine runs, the forks work but the not drive. I have checked the fuse which is OK, handbrake switch is also OK, but I do not have any manual repair, so i need the wiring diagram and ideias!!
number 70371748
Thanks.
Hello,
Please send information for u200.
Thank you.
Hello
can anyone to send me electric drawings for u200 and u36 board
Best regards
Nikola
Hi Jerry
Can you send me the drawings you do have.
Thanks
Greg
Hi Jerry
Thanks
Greg
Hi
I have a 1990 still r70-45 merc diesel forklift but no wiring diagrams can anyone help, as the truck will not move forward or back but does rev up as you step on the pedals
Thank you
Greg
Hi, I am also after a wiring diagram for a R70-16 with a VW engine and is powered by LPG.
The engine runs, the forks work but the truck will not drive. I have checked the fuse which is OK, when you hold the coil in it will then drive, so the fault is on this safety circuit which includes the handbrake switch, but I do not know what else is in this circuit, hence needing the wiring diagram.
Thanks.
hello every body,i am new in this forum too.i have still R70-40(old diesel),the engine is ok but when we want to move it the BUV20 (power transistors) of the power board become damage.I would like to have a electric drawing or service manual, every body would you help?thanks.
Hello every body, I am new in this forum,and I have STILL R70 25 (gas),the engine starts normally,forks are ok, but no drive.
Please can any boby send me any wiring diagram or drawing.
Thanks all.
