noisy drive axle
4412T20MS 4 WD OMEGA LIFT Loud squawk / chatter from steer axle / differential. not from ujoints. no noise until wheel is almost at the limit of turn angle. wet brakes have been thouroughly inspected and any and all out of spec parts have been replaced. any ideas? "steponmebbbboom" looks like you are the resident expert.....got any suggestions?
  • Posted 11 Sep 2010 10:38
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
easier to ask forgiveness than to ask permission.
sorry for the late reply, if the brakes are adjusted properly and lock tabs are in place the only thing I can suggest is to double check the diff oil you are using. as i remember a friction modifier had to be added. if the differential is limited slip which as i recall it is, using straight gear oil without the modifier will cause those parts to groan when sliding against each other.
  • Posted 14 Oct 2010 11:43
  • By steponmebbbboom
Komatsu FD25T17
Rail King RK330
