Side Shift slow to one side ?
Hello all, Been a couple good months around here with no problems. Got hired on full time so I am no longer a temp.
So our Toyota 15-32 model which we got fixed with help from the site has another little problem. Nothing is in the Book I received for download, !!!!"THANK YOU"!!!! has nothing in it about the side shift. Notta one little thing. It moves to one side slowly, the other way seems to work well. I am guessing a bad seal inside is allowing it to bypass. I will be looking at any numbers I can get off of it today and purchase a new one inside of 72 hours. Any ideas ? Looks like it could used cleaned up a little before I go working on it..
This is one of those situations where they have "NO" parts for this truck, never have and are just now developing maintenance. SO whatever I buy is good for the shelf. Even if I buy the whole assembly, the old one will get rebuilt, tagged and shelved for the time until I or the next guy uses it.
Take care and how about BOISE !
  • Posted 8 Sep 2010 03:55
  • By PAPABARE
  • joined 17 Jun'10 - 4 messages
Yup, and the first game of the season is tonight and I already told my boss I won't be in tomorrow!
Side shift cylinders are usually fairly cheap and a pain in the a$$ to rebuild. The valve bodies are pretty easy to rebuild. Just order the right seal kit.
  • Posted 10 Sep 2010 01:42
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
THanks Joe,
Saints fan... Well you got your Super Bowl. I think they will have another good year. It is strange, the feeling after winning something like that as a fan. What Now ? Is the feeling, where do we go from here...
Thanks for the input. I already have it apart and will buy a new one if they have it on the shelf and it is cheap enough. If it is a valve problem I will be handing it off to them anyway, Toyota that is... I am so short on proper Hyd. fittings, parts, etc. at this plant. Just not set up for Truck maint.
  • Posted 9 Sep 2010 21:55
  • By PAPABARE
If you swap you lines does the problem move to the other direction? If you disconnect the lines and remove the cyl. and try shifting the carriage manually with a pry bar does it bind up in one direction? With lines disconnected, plug one line and hook up a pressure gauge to the other. Check your readings both directions/both lines and are they the same? If so then you have a bad cyl. If the readings are differnt and there is no binding in the carriage you have a valve problem.
  • Posted 9 Sep 2010 05:58
  • By joe_d
There has to be someone out here that knows about these side shifts. I guess it must be one that stumps all. I pulled the carriage apart a little and the cyl has no identifycation. Very Generic looking cyl. with stoke on either end, no serial numbers, no info in the catalog that goes with the book.
  • Posted 9 Sep 2010 05:12
  • By PAPABARE
Mobicon 2T
Maxlion FDR50
