intermitant lift problem
Upon first arrival, lift would only work about 2% of the time. Lift contactor would not engage, no engage signal. Traced and checked wiring,ok. Tested lift switch,ok. Traced signal to TB5 interrupt switch box, signal in but no signal out. Replaced interrupt switches and diodes in TB5 box. Now lift works about 98% of the time. The tilt thumb switch does not appear to be sticking. Anybody come across this issue before?
  • Posted 7 Aug 2010 00:25
  • By Louis
  • joined 7 Aug'10 - 19 messages
the retractable overhead guard has some switches to keep you from lifting too high with no overhead protection, these may be your problem, have you checked their operations?
truck_tech's question about the contactor armature pin is still valid and can not be accurately checked without disassembling the contactor (and already knowing what you are looking for) to confirm the guide pin is still in place and correctly guiding the armature stroke. however if you are not getting a positive signal to the contactor coil then the search should begin with that signal.
  • Posted 15 Aug 2010 00:25
  • Modified 15 Aug 2010 00:26 by poster
It does have the retractable o/g and a thumb button switch to over-ride the lift for tilting.
  • Posted 14 Aug 2010 22:33
  • By Louis
Does your unit have any options like tilt interlock,or (R.O.G.) Retractible Overhead Guard?
  • Posted 10 Aug 2010 09:59
  • By Truck_Tech
  • United States
Contactor operates freely, gives a solid pull-in and tips are not burned. Motor tests and checks good. The problem seems to be the signal. I get none to the lift contact when I should.
  • Posted 9 Aug 2010 20:10
  • By Louis
Is there any mechanical binding of the lift pump motor contactor? Is the armature guide pin broken off(common problem)?
  • Posted 8 Aug 2010 07:17
  • By Truck_Tech
  • United States
Crown CG33P5
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
