Advice on new forklift
I'm looking for advice on what I should buy for our new truck body division:
Unit will be used to unload trailer loads of utility, flatbed,contractors bodies. It will also be used to install them on trucks. Heaviest body is around 3000#. Will be used inside and out, outside lot is paved. Will have minimun duty cycle, used one would be fine but we need some writeoffs so the boss wants to look at new.
  • Posted 6 Aug 2010 02:05
  • By OSP1
  • joined 6 Aug'10 - 1 message
Edward t is correct in questioning your load center. Make sure you will be able to utilize the forklift you purchase. There is a big difference between the cost of a 3000lbs and 15,000lbs. forklift. I have a customer that makes and installs truck bodies so I have some experience with your type of application and they don't have any 3000lbs forklifts at their facility. I would gladly come to your site and help you determine what forklift is best suited for you. I can only supply new TCM forklifts but also have all makes and models of used forklifts.
You can email me..........tlmorgan94 at comcast dot net.
  • Posted 6 Aug 2010 23:23
  • Modified 6 Aug 2010 23:27 by poster
  • By tcmgirl
  • joined 15 Oct'07 - 28 messages
thanks for the correction. I fixed it now. (and ain't it good we can go back and edit our posts to fix those things)
I think it would not only have been made from kryptonite, it would have to anchored to the floor.
  • Posted 6 Aug 2010 20:11
  • Modified 6 Aug 2010 20:15 by poster
Woops, forgot the "p" in Kryptonite in my previous post. Just glad my high school English teacher wasn't watching. Today I would have blamed it on spell check.
  • Posted 6 Aug 2010 10:43
  • Modified 6 Aug 2010 10:44 by poster
  • By johnr_j
Me thinks Mr. Ed left off a "0" in his jib boom truck recommendation. It should have been a 15,000 lb or one **** of a strong 1500 lb unit made out of Krytonite.
  • Posted 6 Aug 2010 08:37
  • By johnr_j
wow a company doing so well they "want" new... that sounds like music to a bunch of us, I bet.
Part of what you do not provide us with is what we call the "load center" that being just how far out from the carriage is the center of gravity of your load, do you have to lift these bodies longways (from the front and rear) or do you move them as a sideways load (left and right sides)? while a 3500lb capacity might be fine if your load is only 48inches wide and evenly distributed, if your loads are 80 inches wide and 144 inches long and must be moved from the rear and hanging from a jib boom you will need about a 15000lb truck to handle that load.
  • Posted 6 Aug 2010 08:30
  • Modified 6 Aug 2010 20:11 by poster
Toyota 4FD240
Terberg RT403
Toyota 4FD240
Terberg RT403
