6G "LIFT SHUTDOWN" ERROR CODE ON DISPLAY
i'm working on a Raymond R50-040QM stand up electric forklift. right before showing this error code lift, tilt and side shift were operating very slowly. we then replaced hyd. filter (spin on type ) and hyd. oil was also replaced using "46R low temp oil" then error code "6G" LIFT SHUTDOWN appeared. lift does travel well in fwd and rev but hyd. functions are inoperable but sideshift still moves slowly. this lift operates in a freezer. thanks, jay
  • Posted 20 Apr 2010 05:39
  • By glenn_levit7
  • joined 10 Jul'07 - 78 messages
you have a problem in a lift motor sensor sir. the system card has sensed that the lift motor temperature sensor is oout-of-range.
  • Posted 29 Jul 2010 02:03
  • By forkliftcity
  • joined 23 Jul'10 - 52 messages
  • cebu, Philippines
don't bite the hands that feed you!
JCB 533-105
Taylor TXB180S
