Yale ERC040AHN
I've got a ERC040AHN48TE094 ser C814N01710D that's got a line contactor problem. It seems to be really finicky when trying to turn it on. When turning on the key switch, the dash display will show a code 7, no battery level, and the wrench light is on. The line contactor doesn't pull in and no functions will work. Once in a while it start up normally.
Any ideas what code 7 means and what I should be looking for?
  • Posted 24 Feb 2010 15:23
  • By sleepywheel
  • joined 18 Jan'08 - 77 messages
  • British Columbia, Canada
Yup, you're right, ordered the accelerator sensor. Thanks for your help, Garland!
  • Posted 26 Feb 2010 17:32
  • By sleepywheel
Sleepywheel,
Code 7 shows a problem with the accelerator voltage being too high. Follow the check list attached.
Status Code
7
Description
Memory Recall
Circuit
Accelerator input voltage too high when key is first moved to ON position.
No Traction Symptom
Lift truck does not move.
Possible Causes and Test Procedures
* Accelerator unit has a malfunction or is out of adjustment. Maximum accelerator wiper voltage should be 11.00 volts with the pedal fully up.
* Open circuit between accelerator unit and P7.
  • Posted 25 Feb 2010 23:28
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Work Hard and Fish Long
