Hyster J1.50EX Moving very slow
Dear Friends ,
I am having a problem with Hyster J1.50EX forklift the speed settings are good (not on tortoise mode when the speed is limited as per the setting from the display controller). Among the checks, I found all good, the motor, the harnesses, connectors, power line to the inverter (the drive motor is AC, variable frequency and voltage drived), pedal's potentiometer and micro switch are okay as well... almost everything I could check.
When I measured the power output from the inverter toward the motor I found it only 12Vac but very high frequency (cca 20KHz) at full pedal throttle. As the motor is rated 30Vac looks like the inverter is not generating the proper power.
Can some one help me please.
Thanks in advance
Fabian.
  • Posted 8 Feb 2010 15:02
  • By fabian_m
  • joined 8 Feb'10 - 1 message
  • Tamilnadu, India
Also are there any steer switches?
  • Posted 10 Feb 2010 22:35
  • By chublil
  • joined 28 Jul'09 - 187 messages
Fix it right!!!
fabian, does it have a mast switch on it?
  • By chublil
Fix it right!!!
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Toyota 02-2TD20
