Unit Not Working
The Unit was not working do to a possible battery ground. The battery was repaired and installed. The batter shows 38 Volts ( on a 36 Volt Truck ). When key is in on position unit contactor clicks on and does not hold. Then Battery indicator shows no bars on battery charge level.
Swapped batteries and then got 4 bars on the indicator and a code 67-1. Reset mast switch and now unit shows no voltage again. Both batteries are good... What could cause the display to show no charge when volt meter shows battery has enough volts to run the truck???
  • Posted 23 Dec 2009 11:54
  • By rene_d
  • joined 23 Dec'09 - 9 messages
Showing items 1 - 15 of 15 results.
MY 7FBEU15 does not run either. I had service tech in today. He says that my battery is so low that the charger won't recognize that a battery is there? It tests @ 12V and lights work. I've never heard of this before. They say I have to let them bring it to the shop & out charge on teh battery so that teh charger will work?
I'm sorry that pegged mu BS meter.
  • Posted 12 Apr 2016 05:02
  • By walter_j
  • joined 12 Apr'16 - 1 message
  • Alabama, United States
Walter J
edit
  • Posted 24 Dec 2009 10:51
  • Modified 8 Jan 2010 13:29 by poster
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
I dissasembled the display and checked the display lithium battery. It is good. It shows 3.64 volts as needed. And there is no option in the menu to switch from 36 to 48 volt. It shows 36 volt. Unit diagnostic memory shows fault AC in the memory??along with 67-1.
  • Posted 24 Dec 2009 10:48
  • By rene_d
edit
  • Modified 8 Jan 2010 13:28 by poster
  • By rick_c
Its also now showing what appears to be a "H" inside a box. It is very small and is blinking.
  • Posted 24 Dec 2009 09:20
  • By rene_d
Ok now unplugged battery, then plugged it back. Turned keyswitch and now its NOT showing code 67-1 but it still shows AC and on the display there is no bars on battery indicator. Still beeping. ???
  • Posted 24 Dec 2009 09:17
  • By rene_d
just arrived and initial battery plug In had contactor close and showed full charge with code 67-1 and AC both blinking. Turned it off and restart then contactor attempted to close then opened it shows no bars on the battery charge level and flashing 67-1 and AC while beeping.??
  • Posted 24 Dec 2009 09:06
  • By rene_d
I am buying the replacement battery for the display. What your saying makes sense. If the battery is dead or almost dead would it cause the settings to change on their own? if so that would explain why I am not getting a Battery reading on the display then all of a sudden twice I did get a reading...it was weird..
  • Posted 24 Dec 2009 08:00
  • By rene_d
edit
  • Posted 24 Dec 2009 07:55
  • Modified 8 Jan 2010 13:27 by poster
  • By rick_c
maxlftatsbcglobaldotnet. the truck has not been operating for a month or so. The previous mechanic thought it was the battery. They had the battery replaced. When I installed the battery it worked fine. I drove about 50 ft and it shut down. Now I turn the key and I get an initial contactor close then it opens. The display lights up and shows the wrench and no bars on the battery display while blinking. Twice during start up I had the contactor stay closed and received 5 bars on the battery display along with a code 67-1. This only happened twice and since then it shows no bars and a wrench while display blinks...
  • Posted 24 Dec 2009 07:40
  • By rene_d
edit
  • Posted 24 Dec 2009 07:20
  • Modified 8 Jan 2010 13:26 by poster
  • By rick_c
How do I access the options settings? What is the process step by step...thanks.
  • Posted 24 Dec 2009 06:32
  • By rene_d
edit
  • Posted 24 Dec 2009 06:27
  • Modified 8 Jan 2010 13:25 by poster
  • By rick_c
Would this cause the unit to not work at all.. It doesn't travel or lift. The contactor doesn't stay closed. Unit is inoperable.
  • Posted 24 Dec 2009 02:17
  • By rene_d
edit
  • Posted 24 Dec 2009 01:02
  • Modified 8 Jan 2010 13:23 by poster
  • By rick_c
Sue Tomic Sue Tomic
UN Forklift FBT18NQZ1
Crown SX3030TT4250
Sue Tomic Sue Tomic
