Hydraulic problems
I Have Hyster Lift model H225-E, after engine start in 3 second oil coming back to hydraulic tank
and over fill, I try to fix and replaced main hydraulic pump, but problem continuous
Please I need idea to fix,
thank you
  • Posted 6 Nov 2009 08:12
  • By lou_m
  • joined 6 Nov'09 - 4 messages
  • New Jersey, United States
Mr. David, last few month I working Caterpillar dealer in Indonesia and currently I am been resign.
I need your assisten to gety Technical information about Mitsubishi forklifts especially on System operation every compoenent for Mitsubishi FD20NT, FD50KT AND FD150ANT. Are you know which adress I need to access online. Thank's. Nasrodin
  • Posted 30 Nov 2009 08:17
  • By nasrodin_p
  • joined 30 Nov'09 - 1 message
  • West Papua, Indonesia
Thanks Again Richard, I start work under your direction.
I send message after job-
  • Posted 13 Nov 2009 05:17
  • By lou_m
Dear lou. Do you have one or two hydraulic pumps. If there are 2 pumps then one will be for the lifting and the other is for the steering. If you have a steering pump, please check whether is there any oil coming out from the discharge side. If there is no oil then problem with the pump. If there is oil, please check whether oil is going into the torque generator. When you turn the steering handle, oil will be coming out from the steering valve to the steering cylinder. If oil is going into the cylinder and the wheels do not move then you can look at the steering cylinder seals. Hope this information help. If you have only one main hydraulic pump then it will be advisable to look at the priority valve
  • Posted 13 Nov 2009 05:08
  • Modified 13 Nov 2009 05:10 by poster
  • By richard_y
  • joined 9 Feb'07 - 66 messages
  • Singapore, Singapore
Thanks Richard, Fork, tilt, and system is work good, Just Steering NO work with engine
runing
Hyster-Model H225-E
  • Posted 9 Nov 2009 03:16
  • By lou_m
dear Lou
Normally priority is always given to the power steering. You may have problem with priority valve. Can you turn the steering wheel when the engine is started? What about when you operate the lifting and tilting functions. Do they operate? If possible get the hydraulic diagram to check.
  • Posted 9 Nov 2009 01:24
  • By richard_y
Thanks Willie, but I blower all lines, and I clean 100% all hydraulic system, to day I work
for 7 hrs. and I find one line from main hydraulic pump send direct pressure to Power Steering
Pump (mounted on Steering column)pressure is OK but NO have steering power, my idea
the problem coming from Steering pump in self.-
If you have same Idea please contact me, Thank you AGAIN Willie
  • Posted 7 Nov 2009 11:35
  • By lou_m
Tou may have a clogged Hydraulic tank vent filter
  • Posted 7 Nov 2009 08:03
  • By willie1006
  • joined 5 Nov'09 - 3 messages
Ncn 85TH
Ncn 85TH 2014
Maxlion R2D25
Hawker Powersource, Inc.
