11505
I get codes 30-1, 30-2 as in lift modes, cycle key, may work for 30 sec or 30 days, any insight
  • Posted 30 Oct 2009 02:26
  • By Barfly_olaf
  • joined 10 Oct'09 - 81 messages
  • Nova Scotia, Canada
SEMPER FIDELIS
Thank you, I was that lucky, contactor was not snapping in and tips were burnt, replaced and a one
  • Posted 17 Nov 2009 01:45
  • By Barfly_olaf
SEMPER FIDELIS
those codes can be caused by bad contact tips or conections at cable terminals. you're probably not going to be that lucky because it can also be caused by the (cpu) the main contactor needs battery voltage to pull in then the voltage is lowered to somewhere around 10v to hold in and not overheat the coil. what happens sometimes is that the pull in voltage never happens so the contactor does not get fully pulled in. if you open the right side panel, turn the unit on, reach in and push the contactor manually and it pulls further in and locks you got a cpu problem. there is homemade relay / timer circuit that you can make but its a sneak attack and not a sanctioned repair.
  • Posted 30 Oct 2009 03:30
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
Enforcer FLBAXT25
UN Forklift FBRP15NQZ2
Muncie, IN, United States
