YALE MODEL GLP050 WONT'T SHFT INTO GEAR BUZZING RELAY HELP?
FORKLIFT RUNS GREAT AND HAVE NOT HAD A PROBLEM WITH THE TRANSMISSION FULL FLUID,NEVER SLIPS. TODAY IT DECIEDS NOT TO SHIFT FORWARD OR REVERSE. UNDERNEATH THE CONSOLE IS A NIPPON DENZO RELAY PART NUMBER 056700-5160 IT WAS CLICKING ON AND OFFBUZZING NEVER HEARD BEFORE.COULD THAT BE THE CULPRIT?
THANKS
SEAN
  • Posted 5 Oct 2009 06:13
  • By sean_h
  • joined 5 Oct'09 - 3 messages
Disconnect the linkage and try to shift the lever at the control valve by hand. You may have sheared the roll pin that passes through the linkage and the actuator shaft that goes into the control valve. This was very common on those machines, you may even find the whole worn out and loose on the shaft. If you do, simply drill it out and the holes in the link to match the next size up roll pin. I did this repair many times and if you have a long enough drill bit you dont even have to remove the control valve.
  • Posted 18 Oct 2009 15:58
  • By bigGlittlestar
  • joined 12 Aug'08 - 139 messages
  • United States
The switch you see by the steer column is the nuetral safety switch. If this has failed the lift would not start. Since you have a mechanical linkage for shifting, does everything move when you shift the lever. Make sure the arm on the transmission is still connected. If everything looks fine then I would say something has broken or come loose inside the valve body.
  • Posted 17 Oct 2009 04:14
  • By garland_m
  • joined 16 Oct'09 - 224 messages
  • Virginia, United States
Thanks for the help the model number is GLP050RCJUAE086. It is a mechanical shifter but there is a switch what looks to be a a relal on top of the steering console it is round black with 2 wires coming off of it. There is a series of notches on the steering column that coincided with the shifter. It does beep when put into reverse.
Yhanks again,
sean
  • Posted 15 Oct 2009 08:23
  • By sean_h
Check The Switch In The column, If You put it in reverse does the back up lights and or beeper come on?
  • Posted 10 Oct 2009 07:27
  • By Howitt
  • joined 13 Feb'09 - 80 messages
We'll need the rest of the model number to really help...
However, I can't think of any glp's that used a relay to activate the direction solenoids...
The buzzing points to an electrical problem. Assuming the transmission is electrically shifted, I'd look at the direction switches and related wiring.
  • Posted 8 Oct 2009 23:28
  • By mike_n
  • Alberta, Canada
REPOWERTEK Inc
Maxlion FB30EH
Terberg YT220
