toyota code C4-5
Newer LP gas truck with code C4-5 flashing. Can anyone point me in the right direction
Thanks
  • Posted 26 Sep 2009 04:36
  • By Dmac
  • joined 10 Jul'07 - 10 messages
  • Indiana, United States
Thank you
  • Posted 30 Sep 2009 04:42
  • By Dmac
all of the C4 (C4-1 through C4-5) codes are accelerator sensor related. usually this is a bad connection at the sensor but can be caused by moisture in one of the connectors between the sensor and the engine controller. check the connectors for secure locking and make sure no moisture is present. this can also be caused by over rotation of the sensor (ie pedal to the floor with stop bolt missing or loose). remove the battery cable for about 15 secs after you check for problems and this should clear the code.
  • Posted 26 Sep 2009 06:26
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
Mitsubishi FGE35AT
Maxlion FB30LI
Mitsubishi FGE35AT
Maxlion FB30LI
