C 28 foults on BT spe 125
can I have a electric schema, better an manual for this machine, I tray to repair for 5 day,s, everithinc is think is ok,but start dyrectly with C 28
  • Posted 2 Sep 2009 21:52
  • By alexandru_s
  • joined 2 Sep'09 - 3 messages
  • ROMANIA/EUROPE, Romania
Check hydraulic contractor not welded
  • Posted 7 Mar 2014 08:03
  • By fredjones
  • joined 13 Jun'11 - 19 messages
  • m nm n, United Kingdom
Hi,
I have the same problem with BT SWE 160D PTC resistor heats up and displays an error C28. What causes this condition? Thank you for your help.
  • Posted 6 Mar 2014 17:52
  • By blazej_f
  • joined 6 Mar'14 - 5 messages
  • Pomorskie, Poland
Hi Alexandru,
I have the same fault code on a BT P24 Stacker with curtis 1243C 4382 fitted.
Could you send info to me please
[email address removed]
  • Posted 5 Aug 2010 01:59
  • By stephen_h
  • joined 18 Aug'09 - 11 messages
  • Newcastle, United Kingdom
Hello Alexandru,
The C28 code is probably indicating that the emergency cutoff switch is activated or defective. Check also a PTC resistor in K10 principal contactor if it is open.
Give me a mail and I'll try to send it to you.
Regards
  • Posted 26 Sep 2009 23:46
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Toyota 02-8FD25
SMV (Konecranes) 20-1200B
Noblelift
Noblelift
