loss of power to lpg lockoff valve
has anyone come across this fault before ?
the unit will run fine for two to five minutes then the power to the lpg lockoff valve drops out and the charge light flashes. wait a few minutes and it will start up and drive as normal. even when the power to the valve drops out the engine still has spark and if you bypass the valve it will run but at 1/2 speed and charge light flashing.
thank you
  • Posted 10 Aug 2009 19:29
  • By mrforklift
  • joined 10 Aug'09 - 39 messages
  • Queensland, Australia
Thanks mrforklift your right it was the controller but i ordered 1 & fitted it a service ex controller, I've only just seen your post,
Many thanks for your reply.
  • Posted 17 Sep 2013 02:52
  • By richard_m
  • joined 11 Apr'13 - 112 messages
  • lancashire, United Kingdom
Yes I did
The fault was inside the computer. There is a fuel relay on the board and the solider breaks away. Quite easy to see and repair.
Hope this helps you as I racked my brains over this fault and was told by linde I need a new computer. The person who replied to my question was a great help and the forklift is still running.
Good luck :]
  • Posted 16 Sep 2013 20:29
  • By mrforklift
Hi did you find out what this problem was???
  • Posted 11 Sep 2013 04:40
  • By richard_m
Terberg RT403
Crown CG33P5
Michel Denis Michel Denis
