Would This Work? Advice Please
Do you think this would be a good setup for a van inverter?
i583.photobucket.com/albums/ss276/ThePaulSmith/invertercopy
.jpg
  • Posted 17 Apr 2009 06:45
  • Modified 17 Apr 2009 06:53 by poster
  • By uplift
  • joined 28 Mar'09 - 66 messages
  • lincoln, United Kingdom
upliftuk@gmail*com (*=.)
then the only question would be to use a large enough (amp capacity) relay. I would also make sure the relay was rated as "continuous duty" and not intermittent duty
  • Posted 18 Apr 2009 06:32
  • Modified 18 Apr 2009 22:58 by poster
the relay would allow the leisure battery to charge when the engine is running.
  • Posted 18 Apr 2009 01:26
  • By uplift
since the switch is between the "main" battery and "leisure" battery, the leisure battery will not get charged by the vehicle charge system and will be able to be run down by the inverter.
  • Posted 17 Apr 2009 20:25
Maybe the negatives should be connected and not running through Earth?
  • Posted 17 Apr 2009 06:51
  • Modified 17 Apr 2009 06:52 by poster
  • By uplift
