Anyone know the weight of a 1967 Clark C20B?
Have to trailer from brooklyn to providence and want to make sure I get right capacity trailer.
Thanks,
Sam K.
  • Posted 26 Mar 2009 07:26
  • By sam_k
  • joined 25 Feb'09 - 10 messages
  • Rhode Island, United States
mrfixit was correct in his weight assessment. I was providing a weight of a 4000lb. unit. Guess I worked with the metric capacity reference in the truck model number too long. Meaning 20 would equal a 4000 lb base unit. In 1967 the 20 meant 2000lbs. Sorry.
  • Posted 27 Mar 2009 07:15
  • By johnr_j
"Have An Exceptional Day!"
Just in case you need an automatic transmission, torque converter or if you like doing the transmission yourself, I have overhaul kits with everything in it to rebuild the whole transmission. Call me 1-440 668 7955
  • Posted 26 Mar 2009 23:01
  • By philip_faller
  • joined 15 Oct'08 - 7 messages
Transdoc
The problem with trailering a forklift truck like this is how do you get it up the ramps and even if the trailer has the capacity will whatever you're pulling the trailer with be able to stop quickly when the need arises?
  • Posted 26 Mar 2009 22:00
  • By duodeluxe
  • United States
duodeluxe
It weighs more like 5500 lbs.
  • Posted 26 Mar 2009 12:35
Without knowing the exact specifications of the unit- ie 3 stage or two stage mast, attachments installed or not, etc, etc. Assuming a 3 stage mast w/side shift, forks 9500 lbs would be a good number to work with.
Just food for thought: a 42 year old forklift (any brand) isn't worth the cost to transport it any where if you have to pay for it - even if it only the cost of fuel.
  • Posted 26 Mar 2009 11:29
  • By johnr_j
Maxlion MTF25-60-2WD
Taylor T520M
