Still R 70 FOrk lifter
Hi,
DOes anyone have any ciruit diagram of this lifter? My fault is that the lifter does not change direction of driving motor. Any help is usefull. thanks
  • Posted 6 Mar 2009 22:25
  • By clinton_c
  • joined 19 Jan'09 - 3 messages
  • ss, Malta
Clinton
Hi Clinton,
pls let me know your truck serial number, you should have an id plate on your truck. if the id plate is missing check the chassis for a stamped number - can be located either in the area of the front wheel arches or under the overhead guard on the rh side.
Brad
  • Posted 13 Mar 2009 08:41
  • By JBrad
  • joined 3 Feb'09 - 14 messages
  • Lancs, United Kingdom
Thanks for your help Brad.
Since i never worked on one of these can you please tell me where to find the current sensor. If you have circuit diagrams can you please send them by e mail on clintoncutajar @ yahoo.com. Thanks again
  • Posted 12 Mar 2009 16:06
  • By clinton_c
  • ss, Malta
Clinton
Hi Clinton,
it sounds like you have a problem with your current sensor, does the problem occur when you change direction from forwards to backwards or from backwards to forwards - if the answer is both then check the current sensor!
Brad
  • Posted 12 Mar 2009 06:35
  • By JBrad
Noblelift
Maxlion R2D25
Aichi SR18A
