Hyster W40Z display issues
Has anyone run into this problem. Fully charged the battery display shows 4 green lights. As the battery is discharged, it will only drop to 3 green lights. It gets to the point where error codes are coming up due to low battery but it still stays at 3 lights.
Have changed batteries, displays, control cards. There isn't anything left in the machine.
  • Posted 12 Feb 2009 08:06
  • By Jmwhitti
  • joined 20 Jun'08 - 5 messages
  • Alberta, Canada
Hello! Try changing the charge Algorithm using the handheld. let me know.
  • Posted 21 Mar 2009 03:38
  • By silvio
  • joined 30 Sep'08 - 29 messages
  • buenos aires, Argentina
EMAIL silvio_jorge@hotmaildotcom
check the wiring to the display. is the machine used on a rough floor. could be a break/make connection when going over bumps. pull every wire on every plug
  • Posted 11 Mar 2009 05:02
  • By kevin_k
What zapi controller is in the machine?????
  • Posted 11 Mar 2009 04:32
  • By DAMO
  • joined 9 Jan'07 - 196 messages
  • DUBLIN, Ireland
Yes it is the Zapi. All adjustments are fine and there aren't really too many the change with the hand held analyser.
  • Posted 11 Mar 2009 04:13
  • By Jmwhitti
  • Alberta, Canada
Is this the zapi system hyster? I had similar issues with the ev100 system on the hyster E2.5 and 1.75. It was down to adjustments in one case and in the other case bad connections and a problem with the current sense wires which apparently hyster changed and resolved the problem. Dont know about this particular model will look into it
  • Posted 13 Feb 2009 19:59
  • Modified 13 Feb 2009 20:19 by poster
  • By elektrodrive
Autolift E180AT36B-D5-180
JCB 533-105
REPOWERTEK Inc
REPOWERTEK Inc
