I need a YALE Engine Spec
I am in need of an engine spec sheet for a Yale model year1968, KG51T-50U with a Chrysler 6 cyl flathead model 6A-215. I need to verify the horse power for a state grant rebate program.
  • Posted 17 Jan 2009 03:49
  • By chuck_f
  • joined 17 Jan'09 - 4 messages
I have an old Yale lift, dual wheels in the front we removed the Hercules diesel and have installed a 230 flathead Chrysler. I am in need of a few parts. A starter, Carb and exhaust manifold. The engine came out of a tub and the exhaust exist to the rear of the engine that is right were the master cylinder is. I need to have a manifold the exists in the center or front of the engine. Any help on these parts would be helpful. You can contact me via email at fred at shoprci dot com.
Thanks!!
Fred
  • Posted 31 Oct 2011 10:23
  • By fred_r
  • joined 31 Oct'11 - 1 message
Mr Fixit,
Let's try this.
Chuck dot ford at tlotx dot com
Otherwise my fax is 713 699 6525
Again thanks.
  • Posted 18 Jan 2009 06:27
  • By chuck_f
this forum removes your email
you have to edit it
chuck's email is
chuck.ford (AT) tlotx.com
the only time you can still see it is if the last post is the 1 the site censored and you hit (reply)
  • Posted 18 Jan 2009 06:05
  • By justinm
My e-mail address is [email address removed] I am a salesman for a Housto dealer.
Thank you for your help,
Chuck
  • Posted 18 Jan 2009 01:44
  • By chuck_f
I can do that. It is 4 pages. What E mail address or fax number you want it sent to?
  • Posted 17 Jan 2009 22:14
Mr Fixit,
This is a IND30 model. I belive that you are correct.would you have access to a spec sheet showing the engine info and horse power that you could forward to me? I would be a big help.I can send you afax or e mail address if needed.
Thank you, Chuck F.
  • Posted 17 Jan 2009 12:00
  • By chuck_f
The only Chrysler flathead engine that I know of that was used in 1960's K51 Yales was a IND30. 230 cid, 3 1/4" X 4 5/8", 72 horse power.
  • Posted 17 Jan 2009 09:28
Kai von Berg Kai von Berg
Hyster
