C6000CB No Spark
Specs:
Year: 2014
Make: CombiLift
Model: C6000CB
Engine:3.0 GM IMPCO Tier 4
Good Afternoon, I have this unit (listed above) and I'm not seeming to get spark and I believe fuel injection aswell, Unit was running great and driving under its own power for days. I let the unit sit over the weekend I come back to a crank no start, I've replaced a lot on this unit as it is a Recondition Job, and I received this truck in literal pieces on 3 pallets. I've replaced the starter, plugs, wires, dist. Cap and rotor, completed a head job, all fuses and relays, battery, throttle body, radiator, so on so on, this was before it wouldn't start and it ran great, no CEL, no codes, no missfire, no rough idle, unit was done and got painted, receive the truck starts runs fine, let sit over the weekend and come back to the no start, diaging the problem I found no spark, checked continuity on wires going to distributor and they are good, going to coil, they are good, confused I replaced all the engine fuses (only 3 of them) and it started but ran rough and had codes, codes came up to be injectors 1-4, deleted the codes and the CEL stayed off, turned unit off and wouldn't start back, replaced the fuses again and still won't start, I leave the truck alone to work on another job and come back to it, unit started and running rough, this time no codes, confused I used the IMPCO systems and disabled injectors one by one to find the missfire, cyl 4 made no difference when deactivated, checked injector wires and got intermittent power, checked continuity and it was flawless (checked harness and no nicks, bends, cracks, etc) checked the rest of the injectors, same thing but only injector 4 wouldn't make a difference in the way it ran, replaced all 4 injectors, and went to turn it on, no start, irritated I check all wires to ignition (spark and fuel) and getting 0v on everything key on, spoke to combilift themselves and was givin the run down on what to look for, how to diag and found a relay that gave power to all ignition related systems (spark and fuel), relay tested good, used my meter to check voltage and noticed when key on I would get power for about 1-2 seconds and then nothing (usual with fuel injected systems to deliver fuel to the combustion chamber) but when the key was turned to the start position I would still receive 0v on all systems (unit will still turn over) key back into on and still no power, turn the truck off and turn it back to on and still 0v, but if I kill the truck with the red kill switch and turn it back on I get 12v for the same 2 seconds and then back to 0v, even stranger I will get SPARK just by turning the truck in the on position for the 1-2 seconds it gives power, I'm lost on what this could be, combi rep said Computer is bad or a bad crank sensor, replaced crank sensor to no avail, anyone else seen this? Any other routes or measures I should take? I apologize for the long read, but a lot was done and I'm still not receiving power as I should, thanks for the help.
  • Posted 19 Jul 2025 04:45
  • By UPOW
  • joined 19 Jul'25 - 6 messages
  • GA, United States
UPOW
Key on, power at fuse for 2 sec, then no power, fuse is good, relay is tested good, swapped relay for another and getting the same results, thinking this may be a ECU problem after all? Relay seems to open after those 2 seconds and won't close again when key is in starting position, as to why I'm not getting fuel nor spark
  • Posted 22 Jul 2025 03:52
  • By UPOW
  • GA, United States
UPOW
UPDATE: This morning I replaced the engine harness with the spare I had, everything plugged in, new fuses, relays in place and still no spark, no fuel, no power to anything ignition wise, basically doing the same thing it was doing before I swapped the harness, all grounds checked, cleaned, inspected
  • Posted 22 Jul 2025 03:38
  • By UPOW
  • GA, United States
UPOW
Hi,
You mentioned that it was different with Key off versus key off and Isolation switch off. Check both the key switch and isolation as these may be worn and may be impacting your tests. As you are in the US, you contact the Combilift US based Technical Team. They are based in Greenboro NC. If you go to www.combilift.com, scroll to the very bottom, you can submit a "Technical Support" request. The form asks for truck SN, contact tel no, etc to help identify the problem and to contact you back. The tech team will then contact you. Here is a direct link here https://warranty.combilift.net/technical-support-form/
There is no limit on the questions, truck age etc, and no charge for the support
Hope this helps,
Richard
  • Posted 21 Jul 2025 18:36
  • By Richard_Irwin
  • joined 20 Feb'20 - 81 messages
  • Monaghan, Ireland
Yeah problem with continuity is that when your circuit checking you have to disconnect the circuit on both ends to get correct readings. Specially when checking power supply wires for shorts to ground because if it is still connected it will find a way to ground through other components.
High ohm reading could indicate a poor or open connection and low could indicate a shorted or full connection.
As for the CAN bus system im not 100% sure. Your definitly correct that on most other vehicles 60ohms or close to would indicate a good system as they have more than 1 module on the bus requiring 2 terminating resistors. But the Combilift only has 1 module on the bus and isnt communicating to anything unless you have an lcd display like on the newer units. Units with 1 module on the bus usually have the second terminating resistor built into the diag connector or the dongle itself that you use to connect to it. So your reading could possibly be ok and seeing as how your were able to communicate with it I wouldnt think there would be an issue.
I found my Impco training for the S3000 ECM and theres some good theory of operation in it. Im assuming this would be the correct system thats on your CB but if it doesnt sound right I apologize.
This is saying
Key On Engine Off.
A) The key switch signal to the ECU (12v) causes the ECU to energize the Power Latch Relay which supplies power to the ECU, Electronic Throttle Body and the various input sensors. The Power Latch Relay stays powered as long as the Key is On.
B) When the key is first turned on the Power relay is also energized supplying power to the Fuel Shut-off Solenoid, Ignition Coil, Fuel Injectors and O2 Sensor. If the engine is not being cranked, after 2 seconds the Power relay will be turned off. The relay will be turned on again if an engine RPM signal is sensed.
Note: Turning the key off and on again quickly will not result in another 2 seconds of Power relay. Only after the key has been off for 20 seconds and then turned on again will the 2 seconds of power been seen again.
The document also refers to the Power relay as the Fuel pump relay later on for some reason.
Following this schematic battery power is supplied to pins 30 and 86 of the Power relay. ECM supplies ground to pin 85. Ground wire from ecm also has a diode in line somewhere in the harness. If you were jumping this then you should have had power supplied to the 20amp power fuse. If you do have power on the fuse but not at your ignition coil or injectors yellow power wire you very well could have an issue with the fuse box or wiring there after.
Since you can communicate with the ecm and crank i wouldnt think there would be an issue with other fuses or relays at this time.
It also goes on to say you can check the ecms control over the injectors with a test light while cranking or a noid light if you had pwer supplied to them. It would be interesting to know if the injector ground and ignition mofule was being pulsed by the ecm during cranking as well indicating it wanting to fire and just missing power to the system.
  • Posted 20 Jul 2025 05:31
  • By BLey
  • joined 31 Jul'20 - 60 messages
Engine wouldn't run when relay was bypassed, I was able to get fuel to push through the system but no injector power to get it to the combustion chamber, no spark to ignite it, Monday I'm going to look over my grounds, check my fuse block (because as mentioned before I was able to get it to run before by swapping the fuses, maybe an internal short by a broken block) I also need to mention, I know stated before that getting continuity wasn't a "tried and true" way of finding the problem but I did want to throw out that I'm getting continuity from power to ground in that relay fuse block side, it's a high number I believe 36ohms, this isn't good correct? Or not supposed to have continuity between the 2 since they aren't necessarily tied to the same wire, including the high ohms could indicate a short possibly? Also would like to mention when ohming out the Hi and Lo can systems (like on most cars or Toyota forklifts for example, you check the ohms between the 2 and if it's 60ohms it means your computing systems are good, 120ohms would indicate a bad controller or ECU etc) I got about 135 ohms when I checked between the 2, asked around to some guys I work with and they said it's not for sure bad because they aren't sure how CombiLifts computer systems run, even the Combi Lift tech said he wasn't to sure as he's never checked them that way before
  • Posted 20 Jul 2025 04:38
  • By UPOW
  • GA, United States
UPOW
When you bypassed the power relay did the engine run?
This will suck if it does end up being a bad ecm thats not available. Ive never had much luck with sending controllers and ecms out for repair.
From everything you said it sounds like powers not going to be your issue for the most part and need to focus on the whole ground side. Engine grounds, ecm grounds and go from there i would even bypass that stupid battery disconnect and run my own fresh ground wires for the ecm to rule those out as well.
I hope your able to find somthing, all this work you definitly need a win!
  • Posted 20 Jul 2025 00:45
  • By BLey
Just read your reply deeper, yes I have tried jumping it to no avail, that's what the Combi support tech told me to do, I do seem to get power to everything, even power at the fuse and relays constantly, I do need to check ground because combi tech said the ECU may not be supplying a solid ground (faulty ECU) hoping that's not the case seeing as they can't be replaced and only shipped out the repair, that's last resort I want to make sure it's 100 percent the problem instead of throwing money at a problem I could've fixed for free
  • Posted 19 Jul 2025 23:30
  • By UPOW
  • GA, United States
UPOW
I appreciate the ideas, Monday I return to work I'll post some before and after pics as to show what I was working with and progress on this job, this job was literally scrap to a functioning unit, everything has been over looked, replaced, and or installed, started with bare frame and motor to a working lift, I do have a spare harness and fuse block I can look over, I have the schematics I will share incase someone else is in need of it and maybe someone can help point me in the right direction if I'm over looking something major, to answer your question, when running the tests I did have oil pressure, unit will run without the oil pressure wire hooked up (found that out because someone seemed to have cut the wire to mess with me) truck would die after not sensing the oil pressure after about 10-15 seconds, and I would read RPMs and Crank variables on the graph
  • Posted 19 Jul 2025 23:24
  • By UPOW
  • GA, United States
UPOW
Sounds like youve done quite alot of digging and replacing already. Just wanted to throw some Ideas your way.
Im more fimiliar with the PSI system then Impco but i think alot of the system is similar.
When you had the impco diag software hooked up to do the injector kill test was the ecm recieving a crank, cam and oil pressure signal?
Continuity checks are ok but not great. Continuity can check out good even on a bad wire thats not capable of handling a load.
Id have to look at my schematic but pretty sure the power relay should supply power to your ignition and fuel system components.
On the PSI system when the key was turned on the ecm would cycle the power relay on for approximatly 2 seconds to do a check then turn it off again waiting for crank sensor signal and oil switch to confirm engine rotation before turning it back on again.
Have you tried bypassing the power relay with a jumper from terminal 30 to 87? Have you checked the relay terminals to see if your missing control ground from ecm or power input?
Have all ecm powers, grounds and key switch signals been checked not just for continuity but loaded voltage drop aswell?
When it was running and you said injector 4 had intermittent power did u confirm voltage was steady on the other 3 injectors? Or trace the wire back to the splice for the 4 injectors?
Sounds like you may even have multiple issues not just one. And like I said i do have info on these but havnt looked at one in a little while. There not very common around where I live.
If I think about it later when Im near my stuff ill take a look to see if I can think of anything else
  • Posted 19 Jul 2025 07:53
  • By BLey
So there was a "updated " fuse block assembly and or recalled block for these issues sometime ago. Block assembly would be cracked and or faulty from unknown causes. Also there was the distribution board below the dash that has had numerous issues with corrosion on them and or plug issues. Sounds like you have a relay issue stopping power. Which runs through the above mentioned components. I've replaced fuse blocks and these boards before and comes back to bite you again. So. Also make sure your direction lever is also in good shape. Moisture on these machines isn't very friendly. A lot of open connections exposed to even humidity and moisture.
Even the key switches used are not very reliable.
  • Posted 19 Jul 2025 07:23
  • By ron_k
  • joined 2 Apr'15 - 128 messages
  • North Dakota, United States
4kliftman
