RC5500
good morning, dear,
Crown RC5500
Shuts off few seconds when turned on
I swap from a working forklift all the modules and the distribution board assembly, battery fully charged.
but it still shuts off seconds after key turned on.
Kindly appreciate any guidance,
  • Posted 3 Jul 2025 23:19
  • By RamKhudan
  • joined 4 Feb'21 - 51 messages
  • Curacao
Ram
ramkhudan@gmail.com
Just for grins , check the positioning switches and tach on drive motor those have to reposition the drive unit in straight ahead as you turn on key and unit needs to see tech at 0
  • Posted 23 Jul 2025 01:56
  • By John_Bradley
  • joined 10 Aug'22 - 260 messages
Jb69
Hi Ron and John,
I swapped the key switch and distribution Panel assembly
Check continuity from key switch to distribution panel, good.
Bypass emergency stop.
It still shuts off
  • Posted 22 Jul 2025 08:04
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
Check the emergency disconnect system and the key switch relay
  • Posted 15 Jul 2025 04:04
  • By John_Bradley
Jb69
good day,
I went back and check,
The battery to frame:= Pos 17.25 Neg 21.48 volts
the 2 contactors Ohms= 47.3 & 47.5. but I replaced contactors anyway.
I checked fuses before & after turning on the key= 38.1 volt. but i replaced the fuses also.
and after contactor closes i had to hold the key in start position to keep contactor closed got= 38.0 volts.
  • Posted 15 Jul 2025 02:23
  • Modified 15 Jul 2025 02:49 by poster
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
Is the voltage at fuses 37.5 on both sides after turning on key ? Did you test line contactor
For voltage at both sides when closing of key switch? I ask because the contacts on line contactor may be at fault also have you tested/ replaced the relay board by the line contactor?
There are several relays inside it
  • Posted 12 Jul 2025 11:44
  • By John_Bradley
Jb69
What if any battery volts to frame. Measure both positive to frame and negative. Above 25 volts. Possibly a battery issue. Measure your contactor ohms. Remove wires and measure the coils. 19 to 21 ohms. Any more than replace them.
  • Posted 12 Jul 2025 11:37
  • By ron_k
  • joined 2 Apr'15 - 122 messages
  • North Dakota, United States
4kliftman
Good afternoon Mr. Ron,
Pin 1&2 has 37.5 volts
Key switch input 37.5
There is 4 wires on the key switch
I replaced all the fuses
I bypass Ed connect 2 wires together
Battery connector good
37.5 at the main fuses.
As soon the key turned on the contactor Will close then fall off same time and everything goes dead.
  • Posted 12 Jul 2025 08:35
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
good day, Mr. John,
it shut off same time, as soon the contactor closes it shuts off.
I will Remove the fuse and check.
thank you
  • Posted 12 Jul 2025 01:01
  • By RamKhudan
  • Curacao
Ram
ramkhudan@gmail.com
What voltage do you see before and after key switch? Also check your EDS switch. FU 3 supplies power to key switch. Remove fuses to check them. As what was stated above, they break and carry power, but won't take the load.
CA 203 on the distribution board pin 1&2 power in. Then TP9 you can test voltage for keyswitch. Also make sure your battery plug isn't melted causing a connection issue.
  • Posted 11 Jul 2025 06:11
  • By ron_k
4kliftman
Does it shut down after you try to operate ?
If so check your main fuses the 500 amp
I've seen the carry voltage but drop out when trying to move they break internally but make enough contact to engage but break apart under load also check line contactor
  • Posted 11 Jul 2025 02:27
  • By John_Bradley
Jb69
  • By John_Bradley
Jb69
Check the connectors on the top and bottom of your distribution board.
  • Posted 4 Jul 2025 00:03
  • By John_Nix
  • joined 4 Jan'23 - 3 messages
  • Tennessee, United States
Philadelphia, United States
Prospect CT, United States
Davenport, IA, United States
Dayton OH/Cincinnati OH, United States
Todd J Doxsee Todd J Doxsee
Sales operations, Heli
Chief financial officer, Cyngn
Executive vice president and chief commercial officer, East Penn Manufacturing
Hoist Liftruck F180-36BOX-CAR
SNORKEL A46JE
